Polish's rustic chrismas cabin scene - Emissive Off - Issue?
Hi I am having some issues getting the Emissive OFF Material settings to work for Polish's
https://www.daz3d.com/rustic-christmas-cabin?srsltid=AfmBOopvD3z80o2WofMKQrrU0MDlrOiIteZpf5_LueIKJA5L561QVDVe
The Emissive is still ON regardless of material chosen.
Has anyone else run into this? or am I just a bit stupid again?
Thanks
  • crosswindcrosswind Posts: 10,251
    edited February 8
    The Emissive Off/On Material Presets are not really well defined... (the vendor better save them as a Hierarchical Material Preset ~~)... but they can work as expected.
    The quickest way: You can Expand Selected with RCCS Rustic Christmas Cabin Preload Scene node selected in Scene pane, select all sub-nodes, apply the material preset. (screenshot 1)
    Or, just select the nodes on which there're emissive surfaces (or select them by using Surface Selection tool...), then apply the material preset (screenshot 2)
    2560 x 1392 - 4M
    2560 x 1392 - 4M
    Post edited by crosswind on
  • MouserMouser Posts: 775
    Nope emmisive lights are still on.
    Looked under surfaces and all are still on.
    Applying the material emmisive off simply does nothing.
    tried switching both the emmision and two side light to off and still no change.
    Okay nothing is working, time for the MS solution (switch off & then switch on again).
    Uninstall package
    Delete package
    Re-download package
    Re-install package
    And it works.
    Okay, all of a sudden now the emmissions off material setting is no longer working again.
    Do I have to re-install products every couple of weeks just to get this stuff to work?
    Okay
    restart DS, no change?
    Shut down & restart PC and its fixed.
    I wish i knew if this was a DS or just tht item thats the issue.
