GPU not working with Daz
Hello, I have a PC with an RTX 5090 that does not seem to be utilizing the video card in Daz Studio 4.24.0.4. I am using cpuid's Hardware Monitor to check for utilization, I am getting near 100% on the Ryzen 9 9950 but 0% utilization under the GPU as well as 0% of GPU memory. I have my GPU checked in the box under Hardware in Render Settings and it also shows up in Preferences under Interface. Running Windows 11 Pro 25H2.
I have another PC with the exact same specs except it has an RTX 4090, GPU utilization is showing as 85%+ of GPU and 50%+ of video memory.
Thank you
  • Richard HaseltineRichard Haseltine Posts: 111,795
    Daz Studio 4.x.x.x cannot support 50x0 cards as nVidia made chnages to the way they compiled the libraries. The Daz Studio 2025 Alpha does support 50x0 cards, so the fx is to use that for rendering while still using DS 4 for scene setup (siince most plug-ins and some scripts do not, yet at least, work in DS 2025) - for the most part this is simply save from DS 4, open in DS 2025 (as long as the content directories match) but if you use Mesh Grabber, and aren't a Premier member, you will need to bake its modifiers to morphs in DS 4 before saving for DS 2025.
  • Thank you Richard.
