How to make the clothes not cling on the body!!
ObsiObsi Posts: 26
Product: https://www.daz3d.com/dforce-mi-two-piece-business-suit-for-genesis-8-and-81-males
Trying this product on G9, and how to make the clothe a little loss. It too fit that it outlines the ABS
436 x 549 - 154K
  • omvendtomvendt Posts: 222
    I think everyone has that question at some point. Vendors have solutions, essentially stuffing, or simulation where the figure grows into the clothes. I use dForceAssistant.
  • Richard HaseltineRichard Haseltine Posts: 111,867
    dForce is an option, but not all outfits will work. A Smoothing Modifier (Edit>Figure>Geoemetry>Add Smoothing Modifier) with generic rather than base shape matching may also help.
  • ObsiObsi Posts: 26
    tried it too but sadly didnt work
    Tried that too and also push modifier. It did help a little but the chest and abs outline still noticeable.
  • Use this technique for the whole body, should help at least a little bit, hopefully:
  • crosswindcrosswind Posts: 10,347
    The issue of "too fitted" usually comes from the generated Auto Follow morphs on the garments. Firstly, check what body morphs (FBM or PBM....) that you dialed on the G9 figure that makes this character muscular or have such fitness shape on the ribs ~~
    Then in Parameters pane, with Show Hidden Properties... turned on, select the suit / shirt, you should be able to find the generated morphs of the above-mentioned body morphs, try zeroing out the morphs or reduce the dialed value... see if the issue can be fixed ~~
