Problem with VERSUS - Secret Lingerie for G8F Pack
Hi,
I purchased [VERSUS - Secret Lingerie for G8F] above item today, but none of the content works. I get the following error message:
/data/powerage/SecretLingerieG8F/Bra/UV Sets/powerage/Base/default.dsf
I installed it via DIM first and when encountering this error as well manually - same result. Is there something I am not getting? It didn't say it is legacy content or anything.
Any help/suggestions would be much appreciated.
  • Richard HaseltineRichard Haseltine Posts: 111,348
    The VERSUS products are material sets for other models, in this case it looks to be a product from Renderotica so I can't link to it. Because you have the materials but not the model it is giving errors when it tries to load the UV set (the instructions that tell the application how to wrap an image around the model) which are set in the material file (because there can be more than one set) - however, you are also lacking the model itself.
    I might be mistaken, but it looks like the base product (Secret Lingerie for G8F by powerage) is available on Renderosity - currently 50% off for the next day and a half.
