Subject: Missing "Clear Selected Deltas from Selected Morph(s)" in latest DS version?
ontent: Hi, I'm trying to edit a morph using Geometry Editor. I have selected vertices, but I cannot find the "Clear Selected Deltas from Selected Morph(s)" option anywhere in the right-click menu or Edit menu. Even in the F3 (Customize) panel, searching for "Delta" only shows "Clear Selected Deltas from Favorites."
Did the name of this function change in the latest version? Or is it moved to a different menu? I am using a custom morph loaded via Morph Loader Pro. Any help would be appreciated!
I am using an AI to translate this message as I only speak Japanese. I would appreciate your kind assistance and patience.
  • Richard HaseltineRichard Haseltine Posts: 111,371
    Hasn't it always been from favourites? I don't recall a from selected option.
  • tsdyk049tsdyk049 Posts: 1
    Thank you for the clarification! I might have misremembered how the menu worked in my older version. I will try adding the morph to "Favorites" first and then see if I can clear the deltas. Your advice was very helpful. Thank you again!
