How to make Omni Hair shaders work in DS 4.15?
CHWTCHWT Posts: 1,191
How to make Omni Hair shaders work in DS 4.15? No luck so far in DS 4.15, either showing up white or translucent in renders lol.
  • LeanaLeana Posts: 13,621
    Support for curves that Omni hair shader uses was added in 4.21, it won't work in earlier versions.
    You will need to use another hair shader.
  • CHWTCHWT Posts: 1,191
    Too bad. Thanks Leana!
  • lilweeplilweep Posts: 2,879
    You would need at least 4.20.1.19 to get them to work as that is when they added iray curves to daz, and then you have to manually add the shaders to your install as those werent added by daz till later, i guess 4.21 as mentioned above
