Converting G8 morphs to G9?
I have several morphs in my G8 library that I find essential to creating characters and I would love to use them on G9 characters, so is there a way to convert G8 morphs over to G9?
  • Have you looked at conversion products on the store, which claim to do something like that?
    There is also a free way, which requires you to dial in the clone onto G9, and make both figures assume the exact same shape/pose.  After you do this, you can run Transfer Utility to transfer across your favorited morphs from G8 and then save them.  (Transfer Utility is not just for transfering rigs!).
    Unfortunately this method will not transfer over any "sub-component" logic, like correctives or adjusted rigging.  So you would need to "Adjust Rigging to Shape" every time you want to use one of these morphs in your library.  If those morphs have substantial numbers of correctives on G8, then re-establishing all of that corrective logic on G9 would be difficult to do manually.
    There are some G8 morphs products for example that have like a hundred dependencies. For example, Auto-Muscle Enhancer i believe has 100s of correctives or subcomponents, and those won't transfer well.
    Maybe some of the conversion products on the store can reproduce this process a bit better than the manual/free way I described above.
