Adding new Character to scene makes them look anorexic
Hi there,
everytime I add a character to a scene (like for example Gillian) they come not in the expected shape. Instead they look like they have nothing to eat for 4 weeks ;-)
So evertime I must Zero the Figure and apply the shape to it.
Where is the error?
  • Richard HaseltineRichard Haseltine Posts: 111,363
    Which base figure? Which application - Daz Studio? - and version?
  • AndyP65AndyP65 Posts: 10
    Genesis 3, Daz Studio 4.8 and 4.9 also.
    It sounds as if you have a morph that was saved with a non-zero default value. Load a plain Genesis 3 Female from the Content Library and in the Parameters pane look at Currently used - I think the defaults should be Navel and Mouth Realism HD set, what (if any) other shapes are non-zero? Does zeroing that one restore the shape to the default?
    You are right!
    The Genesis 3 Female looks well. I found out that the Gillian Character has also set Kimmy Body and Kimmy Head to 100%. If I set this to 0% Gillian is looking good.
    But where did it come from?
    Try reinstalling Gillian - if the non-zero morph slipped in from something you had done that should probably clear it; if not please open a support ticket to report this as a possible bug.
    edited March 2016
    Oh, it's not just Gillian it's every Female Character based on Genesis 3.
    Maybe I try to deinstall Kimmy and do a test.
    Post edited by AndyP65 on
    I uninstalled the Kimmy Character. Delete the Package, restart Daz3d, insert Gillian but in the Parameters I still find Kimmy Body 100%.
    I do the same again, but this time looking for kimmy-files in the library. After deleting the files, reinstall kimmy all works well.
    Kimmy has the right size and the other characters are shown as expected.
    @Richard Thank you for you help
    This Kimmy http://www.daz3d.com/fwsa-kimmy-hd-for-teen-josie-7 ? I'm not seeing the issue, try reinstalling the character now.
    Yes, It's the right Kimmy.
    I reinstalled and all behavior is as expected.
    I can't reproduce it.
