Schrodinger's Shopping Cart
colinmac2
I put Metals Abound product into my cart, THEN I tried to sign in. Now it says my shopping cart is empty, BUT it also says there is one item in it. When I try to re-click on Metals Abound, it says it's "Already In Cart". HELP!
Make sure you are signed in then add something else to your cart. Then you should be able to remove that item and add the one you want.
Thank you. Very helpful.
This is a random error, but there is a fix that usually works. Please add any other item to your cart, both items will then show. You can then remove the unwanted item and proceed to checkout.
