Fitting Genesis 9 hair to Genesis 8 issues
I have a G9 hair model that has a scalp and two additonal hair pieces, Left and right which are fit to the scalp. When I fit the scalp to G8 using the G9 mmx clone it fits well but when I feload the file later it is still fit to the G* but now the hair is offset down into the chest. Unfitting and refitting does not solve the problem. If I delete and refit a new version it works again. Anyone have ideas as to the issue or better yet remedy?
thanks
  • crosswindcrosswind Posts: 10,344
    The hair you menioned sounds like an SBH.  Due to SBH's fitting mechanics, in most cases you're not able to directly make it work by using Auto Fit cross Genesis figures ~~  Besides, Auto Fit breaks dForce Modifier on most of SBHs.
    Suggest you just parent the hair to G8's Head node and tweak the hair's Transforms.(XYZ)
