Problems encountered when adapting Genesis 9 clothing to Genesis 8.( Already solved))
793043235793043235 Posts: 36
edited January 10 in Daz Studio Discussion
当我尝试将G9的服装适配到G8上时,出现了以下选项:该物品最初是为哪个体型设计的?但实际上,Genesis 9的选项菜单中并没有这个选项,导致服装无法完全适配。请问如何解决这个问题?谢谢!
Post edited by 793043235 on
  • felisfelis Posts: 6,595
    Daz included a G8 clone for G9 some time ago.
    If you are using the latest version of Daz Studio, make sure you have the latest version of default ressources.
    Which option do you see when trying to autofit?
    Alternatively there is this product https://www.daz3d.com/mmx-genesis-9-clones-for-all
  • 793043235793043235 Posts: 36
    edited January 9
    felis说:
    Daz 之前曾推出过 G9 的 G8 克隆版。
    如果您使用的是最新版本的 Daz Studio,请确保您拥有最新版本的默认资源。
    尝试自动调整时,您看到的是哪个选项?
    或者,您也可以选择这款产品:https://www.daz3d.com/mmx-genesis-9-clones-for-all
    I used this product, but it didn't work well with G9 stockings. Moving my toes didn't cause the stockings to deform. During the compatibility test, only the Genesis9 MMX product was listed as compatible, but there wasn't a separate Genesis9 option. I'm not sure if it's a problem with my DAZ.
    edited January 9
    The G8 clone for G9 was added some time ago, maybe a year, so if you haven't that clone, I would say there must be something with your installation.
    I don't understand why you can't autofit socks with MMX clones. Here I have just done it.
    1000 x 800 - 587K
    Post edited by felis on
  • LeanaLeana Posts: 13,617
    The G9 autofit clone was added to G8 around the time 4.23 was released.
    It is part of G8 figure, not DS default resources, so try updating G8 starter essentials.
    莉安娜说:
    G9 自动适配克隆功能是在 G8 4.23 版本发布前后添加到 G8 中的。
    它是 G8 模型的一部分,而不是 DS 默认资源,所以请尝试更新 G8 入门必备组件。
    Okay, thank you, I'll try to update it.
    felis说:
    G9 的 G8 克隆版是之前添加的,大概一年前吧,所以如果你还没有这个克隆版,那说明你的安装肯定有问题。
    我不明白为什么MMX克隆版不能自动适配袜子。我刚才已经试过了。
    It can be fitted, but it cannot deform as the toes move.
    1411 x 859 - 334K
    793043235说:
    莉安娜说:
    G9自动克隆功能是在G8 4.23版本发布的,同步添加到G8中的。
    它是G8模型的一部分,而不是DS默认资源,所以请尝试更新G8入门必备组件。
    I updated Genesis 8 Starter Essentials, and the problem is solved. Thank you so much!
