some actions cannot be undone
I often encounter things in DAZ Studio when cannot be undone
by far the most infuriating one is moving  an animated character with the root selected and it pulls the legs out instead
undo usually skips to a previous function often before even loading the animation
today it even skipped and removed all my camera edits
  • The undo function has been borked for a few versions.
    In addition to what you're seeing, i've had LIE, material presets, delete, well, basically anything, not be added to the undo list.
    It's very random when it does or doesn't work.
  • Richard HaseltineRichard Haseltine Posts: 111,253
    I had undo break in DS 2025 a few weeks ago, but I don't recall running into it in DS 4. If you can actually trigger it reliably please report the steps, when it is an intermiuttent and unpredictable issue it is very hard to track down and fix.
    At least in my case, it being unpredictable or replicatable, has been the issue.
    It can skip one action, or 3-4+. I've gone through loading a character, applying material presets, putting clothing on, change clothing materials, and when i wanted to undo a material preset for the clothing, it unloaded genesis.
     Then, i can go through several sessions and not have any issue at all.
    I can't recall when it started, i think 4.22, but it's been happening long enough that I pretty much expect it to happen whenever i need to use the undo command.
    And, it doesn't seem to be hardware or OS related, as it happens on my entire network.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,439
    yeah, very unpredictable and intermittent but the bummed up translation altering the pose is probably the worse one in consequences, again only does it sometimes amd the damage varies
