How to achieve a realistic indoor lighting
Hi everyone. I have a question about how to achieve realistic indoor lighting. I was following the work of an adult artist (Himeros3D) and noticed that in his comics he uses a lot of realistic natural indoor lighting, and I wanted to know what step he used to achieve this result:
I tried using HDRI and ghost lighting, but I'm far from reaching that level. In case anyone is wondering, I'm working on a scene that takes place in a tropical resort, and my characters are inside a resort room, and my goal was to achieve this lighting. Here's roughly how my scene was set up.
Could someone give me some tips on how to achieve this lighting? Thank you!
    Hi, just as an FYI imgur is not available in the UK so no-one from here can see your images :(  It may not matter if you can get help from elsewhere.
    Hello! Sorry, I didn't know Imgur was blocked in the UK. I live in Brazil, and it's still working here. What image upload sites are you able to access?
  • Richard HaseltineRichard Haseltine Posts: 111,363
    You could attach the images to your post - click the Attach a file link under the text entry box, then click Browse and select the image(s)
  • Okay, I've attached the images I uploaded to Imgur to this reply.
    619 x 781 - 403K
    1919 x 1000 - 509K
    Adjusting the Tone Mapping will help - by default it is set for a bright day outdoors, so you will need to adjust the exposure value or the other exposure-related settings (ISO, fStop, shutter speed) depending on which you know (you don't get the trade off with these that you do with a physical camera). You will also want to adjust the dome roatation so that the brightest part of the HDRI is where you want the stroingest light - presumably more-or-less facing the windows. adding a weak ghost light shinging from the back of the room may also help.
    Thanks for attaching the images to the thread. It is pretty silly that we can't see imgr anymore in the UK but it is what it is.
    As someone who also needs to learn more about lighting, I am probably not going to be that helpful and Richard has already given a lot of good advice.  But, if I was trying to replicate that lighting setup I would first look at the shadows from the source image - in your example these do show that the majority of the light is coming from the window and that is a very bright light that is somewhat over-exposed so as the viewer cannot see anything outside the window. This is to simulate a bright sunny day and full sun glare, filtered slightly by the net curtains. If the view of the sea/boat is important in your scene then you'll have to adjust for that in order to combine the two things which will make it more tricky to match. Also, if the outside is just a flat image rather than an HDRI then this will also make things more tricky.
    Lighting is a very tough thing to get good at unfortunately.
    I was trying to replicate this effect using a giant plane with emissive lighting to try and mimic a daytime beach sky, but the scene still remained somewhat dark. I achieved 50.000-80.000 lumens with lighting strong enough to illuminate the furniture near the window, but weak enough for the light to accurately reach my characters.
    My goal was to get close to that lighting in my scene, but keeping the HDRI not as lighting, but as a background, since if I were to use a pane, it would literally cover the entire scene, killing the background with a beautiful beach in the background. I believe this scene would be better done if it actually had curtains, since they act as diffusers, softening the light and creating the look shown in the render.
    Yes, I agree with you. Lighting is something I still struggle with a lot, so much so that my renders never look very realistic because I end up using ready-made lighting assets, which creates something much more "artificial" than natural.
    Ahh, right, so the image out the window is using the a background feature rather than a plane primative? That may still give the opportunity to use a sunny HDRI to provide the lighting but with draw dome set to off - alternatively it may a job for ghost lighting but I have never used those.
    I think that the pre-made lighting packs are good for when you use them for their intended purpose (lighting a model as if in a sudio or the ones that are designed for a specific environment) and also good to use as an example to learn from.  However, for most scenes with natural lighting I think you do need to use a HDRI, even if it is then suplimented with additional lighting sources.
    I have done a little messing about since I need some practice anyway.  I am not sure I have the same assets that you used so I used a similar resort room, view and angle.
    The first image is a raw render with the default HDRI - showing that by default it will be dark and so work has to be done to light it.
    The next one I added a beach & sea photo as a backdrop image under the environment tab and a sunny sky HDRI from polyhaven. This is still not enough to light the room sufficiently.
    To improve this for image 3 I did a few things: firstly I tilted the HDRI on the Z axis to direct the light further into the room - this is fine to do since the dome/HDRI is hidden and so it won't look weird. I then adjusted the Exposure Value from the default of 13 down to 11 which did blow out the scene quite considerably and so I dropped the "Burn Highlights" down to 0.5. The inside was still a little dark and so I added a plane primative which I lifted to the ceiling and gave it a little emission. Nothing too much as I did not want it casting visible shadows or making it look too unnatural but just enough to brighten the general inside some more.  This does make the room look much brighter although the shadows are still quite harsh.
    The forth image I tried to soften the shadows by using a studio HDRI which did achieve that but also made the scene more dull and so probably needs the saturation increased and maybe a further yellow environment tint.
    For completion I also added a different curtain with a closed morph to cover the window.  This didn't diffuse the light as much as I expected but there are probably other settings to improve that.
    1200 x 675 - 83K
    1200 x 675 - 97K
    1200 x 675 - 120K
    1200 x 675 - 122K
    1200 x 675 - 101K
