DzGroupNone behaviours *Solved*
TotteTotte Posts: 15,217
Hi,
I have some issues to get a DzGroupNode created in script to behave similar (give the same results) as a DzGroupNode created using Create->New Group... and enbedding the selected node into the group. See attached image,
I suspect that the DS Action does some behind the scenes tricks (that I very much would like to do myself, to get the same behavoir. I do call invalidateBoundingBoxes() in tghe DzGroupNode after the node has been parented to it.
1128 x 905 - 85K
Post edited by Totte on
  • TotteTotte Posts: 15,217
    Thanks to Rob Whiz and also MikeD for brining clairity to this.
  • DoctorJellybeanDoctorJellybean Posts: 10,193
    Totte said:
    Hi,
     In 4.x DzBox3::include() is bugged in script (it is fixed in 6.x), but translation of the C++ code to script is:
    var boxWorld = new DzBox3();
    var aNodes = Scene.getSelectedNodeList();
    for( var i = 0, n = aNodes.length; i < n; i += 1 ){
     boxWorld.include( aNodes[i].getWSBoundingBox() );
    var vecMax = boxWorld.max;
    var vecMin = boxWorld.min;
    var vecMid = vecMax.add( vecMin ).multiply( new DzVec3( 0.5, 0.5, 0.5 ) );
    if( oGroupNode ){
     oGroupNode.setWSPos( new DzVec3( vecMid.x, vecMin.y, vecMid.z ) );
    The C++ is shorter - operator functions on DzVec3
