Only empty or black render results.
I'm not sure what I've done, but for hours now I've only been getting blank or completely black renders (graphics card AND/OR CPU), no matter how often I reset the render settings or try to fix them using supposed solutions from online tutorials.
Is there any way to effectively reset this without having to reinstall the entire software?
  • felisfelis Posts: 6,625
    edited January 2
    If you look at Render Settings > Hardware what is then ticked?
    If you look in your log Help > Troubleshooting > View Log what does it say when you try to render.
    In Render Settings on top, there is a 'Default' button. I would assume it set render settings to default, but don't know.
    Post edited by felis on
  • My RTX 4070 Ti Super is selected as the hardware, but I've also tried it with the CPU and both, and I've pressed the default button several times.
    The log file shows the following for a single render attempt:
    2026-01-02 19:35:44.141 [INFO] :: Rendering image...
    2026-01-02 19:35:45.392 Iray [INFO] - TRAV:DATABASE ::   1.0   TRAV   db   progr: Traversing scene.
    2026-01-02 19:35:45.884 Iray [INFO] - TRAV:DATABASE ::   1.0   TRAV   db   info : Traversing scene took 492.069 ms.
    2026-01-02 19:35:45.919 Iray (Scene Traversal) : Initializing update
    2026-01-02 19:35:45.920 Iray (Scene Traversal) : Retrieving journal and checking for changes
    2026-01-02 19:35:45.920 Iray (Scene Update) : Updating LPE labels
    2026-01-02 19:35:45.920 Iray (Scene Update) : Updating geometry contexts
    2026-01-02 19:35:45.921 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating geometry contexts.
    2026-01-02 19:35:45.921 Iray (Scene Update) : Updating geometry
    2026-01-02 19:35:45.921 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating geometry.
    2026-01-02 19:35:45.921 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing scene graph.
    2026-01-02 19:35:46.006 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Auto instancing compression 1.0x (Full instancing compression 1.0x)
    2026-01-02 19:35:46.007 Iray (Scene Update) : Retrieving geometry
    2026-01-02 19:35:46.007 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing geometry for motion time 0
    2026-01-02 19:35:46.081 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Geometry import (2 triangle objects with 1 M triangles, 2 instances yielding 1 M triangles) took 74.472 ms
    2026-01-02 19:35:46.082 Iray (Scene Update) : Updating motion transform data
    2026-01-02 19:35:46.082 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating motion transforms.
    2026-01-02 19:35:46.082 Iray (Scene Update) : Updating section objects
    2026-01-02 19:35:46.082 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating section objects.
    2026-01-02 19:35:46.082 Iray (Scene Update) : Updating materials
    2026-01-02 19:35:46.082 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating materials.
    2026-01-02 19:35:46.135 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : found 1125 textures, 0 lambdas (0 unique)
    2026-01-02 19:35:46.135 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Emitter geometry import (18 light sources with 7233 triangles, 1 instance) took 373.300 us
    2026-01-02 19:35:46.148 Iray (Scene Update) : Updating environment
    2026-01-02 19:35:46.148 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating environment.
    2026-01-02 19:35:46.152 Iray (Scene Update) : Updating code
    2026-01-02 19:35:46.152 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating compiled material code.
    2026-01-02 19:35:46.152 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating compiled environment code.
    2026-01-02 19:35:46.153 Iray (Scene Update) : Updating textures
    2026-01-02 19:35:46.153 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating material textures.
    2026-01-02 19:35:46.188 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating environment textures.
    2026-01-02 19:35:46.188 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating BSDFs.
    2026-01-02 19:35:46.188 Iray (Scene Update) : Updating volumes
    2026-01-02 19:35:46.188 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating volumes.
    2026-01-02 19:35:46.189 Iray (Scene Update) : Updating lens data
    2026-01-02 19:35:46.189 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lens.
    2026-01-02 19:35:46.189 Iray (Scene Update) : Updating lights
    2026-01-02 19:35:46.189 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lights.
    2026-01-02 19:35:46.190 Iray (Scene Update) : Updating instance topology
    2026-01-02 19:35:46.190 Iray (Scene Update) : Updating flags
    2026-01-02 19:35:46.190 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating object flags.
    2026-01-02 19:35:46.191 Iray (Scene Update) : Updating backplate
    2026-01-02 19:35:46.192 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating backplate.
    2026-01-02 19:35:46.192 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating compiled backplate code.
    2026-01-02 19:35:46.192 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating backplate textures.
    2026-01-02 19:35:46.192 Iray (Scene Update) : Updating decals
    2026-01-02 19:35:46.192 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating decals.
    2026-01-02 19:35:46.198 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using iray core convergence estimate.
    2026-01-02 19:35:46.199 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Allocating 1-layer frame buffer
    2026-01-02 19:35:46.205 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using batch scheduling, caustic sampler disabled
    2026-01-02 19:35:46.205 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Initializing local rendering.
    2026-01-02 19:35:46.205 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Available GPU memory has increased since out-of-memory failure. Re-enabling CUDA device 0 (NVIDIA GeForce RTX 4070 Ti SUPER)
    2026-01-02 19:35:46.209 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Initializing OptiX for CUDA device 0
    2026-01-02 19:35:46.576 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 1 device(s):
    2026-01-02 19:35:46.576 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info :     CUDA device 0 (NVIDIA GeForce RTX 4070 Ti SUPER)
    2026-01-02 19:35:46.576 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
    2026-01-02 19:35:46.576 Iray [INFO] - IRAY:RENDER ::   1.13  IRAY   rend progr: CUDA device 0 (NVIDIA GeForce RTX 4070 Ti SUPER): Processing scene...
    2026-01-02 19:35:46.577 Iray (Scene Access) : Retrieving geometry
    2026-01-02 19:35:46.577 Iray (Scene Access) : Retrieving device geometry
    2026-01-02 19:35:46.769 Iray (Scene Access) : Retrieving volumes
    2026-01-02 19:35:46.770 Iray (Scene Access) : Retrieving textures
    2026-01-02 19:35:46.776 Iray (Scene Access) : Retrieving device textures
    2026-01-02 19:35:50.504 Iray (Scene Access) : Retrieving flags
    2026-01-02 19:35:50.504 Iray (Scene Access) : Retrieving device flags
    2026-01-02 19:35:50.506 Iray (Scene Access) : Retrieving lights
    2026-01-02 19:35:50.506 Iray [INFO] - IRAY:RENDER ::   1.9   IRAY   rend info : Importing lights for motion time 0
    2026-01-02 19:35:50.506 Iray [INFO] - IRAY:RENDER ::   1.9   IRAY   rend info : Initializing light hierarchy.
    2026-01-02 19:35:50.601 Iray [INFO] - IRAY:RENDER ::   1.9   IRAY   rend info : Light hierarchy initialization took 94.884 ms
    2026-01-02 19:35:50.602 Iray (Scene Access) : Retrieving device lights
    2026-01-02 19:35:50.602 Iray (Scene Access) : Retrieving section objects
    2026-01-02 19:35:50.602 Iray (Scene Access) : Retrieving device section objects
    2026-01-02 19:35:50.603 Iray (Scene Access) : Retrieving materials
    2026-01-02 19:35:50.612 Iray (Scene Access) : Compiling custom code
    2026-01-02 19:35:50.612 Iray (Scene Access) : Retrieving environment
    2026-01-02 19:35:50.620 Iray (Scene Access) : Retrieving device environment
    2026-01-02 19:35:50.624 Iray (Scene Access) : Retrieving backplate
    2026-01-02 19:35:50.624 Iray (Scene Access) : Retrieving device backplate
    2026-01-02 19:35:50.624 Iray (Scene Access) : Retrieving decals
    2026-01-02 19:35:50.624 Iray (Scene Access) : Retrieving device decals
    2026-01-02 19:35:50.625 Iray (Scene Access) : Retrieving motion transform data
    2026-01-02 19:35:50.625 Iray (Scene Access) : Retrieving device motion transform data
    2026-01-02 19:35:50.625 Iray (Scene Access) : Retrieving lens data
    2026-01-02 19:35:50.625 Iray (Scene Access) : Retrieving device lens data
    2026-01-02 19:35:50.655 Iray [INFO] - IRAY:RENDER ::   1.9   IRAY   rend info : JIT-linking wavefront kernel in 23.545 ms
    2026-01-02 19:35:50.669 Iray [INFO] - IRAY:RENDER ::   1.13  IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 4070 Ti SUPER): Scene processed in 4.093s
    2026-01-02 19:35:50.670 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(373): Iray [ERROR] - IRAY:RENDER ::   1.13  IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 4070 Ti SUPER): Not enough memory for kernel launches (700.850 MiB (out of 700.850 MiB total) still required, 0 B available). Cannot allocate framebuffer.
    2026-01-02 19:35:50.670 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(373): Iray [ERROR] - IRAY:RENDER ::   1.13  IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 4070 Ti SUPER): Failed to setup device frame buffer
    2026-01-02 19:35:50.671 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(373): Iray [ERROR] - IRAY:RENDER ::   1.13  IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 4070 Ti SUPER): Device failed while rendering
    2026-01-02 19:35:50.671 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(373): Iray [WARNING] - IRAY:RENDER ::   1.13  IRAY   rend warn : CUDA device 0 (NVIDIA GeForce RTX 4070 Ti SUPER) ran out of memory and is temporarily unavailable for rendering.
    2026-01-02 19:35:51.155 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(373): Iray [WARNING] - IRAY:RENDER ::   1.13  IRAY   rend warn : All available GPUs failed.
    2026-01-02 19:35:51.156 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(373): Iray [ERROR] - IRAY:RENDER ::   1.13  IRAY   rend error: Fallback to CPU not allowed.
    2026-01-02 19:35:51.156 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(373): Iray [ERROR] - IRAY:RENDER ::   1.13  IRAY   rend error: All workers failed: aborting render
    2026-01-02 19:35:51.156 [ERROR] Iray :: Internal rendering error.
    2026-01-02 19:35:51.336 [INFO] :: Saved image: C:\Users\Ingo\AppData\Roaming\DAZ 3D\Studio4\temp\render\r.png
    2026-01-02 19:35:51.337 [INFO] :: Finished rendering.
    2026-01-02 19:35:51.429 [INFO] :: Total Rendering Time: 7.39 seconds
  • I forgot to mention (in case this is relevant):
    The DAZ Studio version currently in use is 4.24.0.3
    The log states that you have run out of VRAM and CPU fallback is disabled - double-check that you have not accidentally blocked the CPU fallback.
    Also, I am not an expert but 2 instances of 1 million triangles sounds like a lot so make sure nothing in the scene has an unusally high SubD?
  • schlumpenhuberschlumpenhuber Posts: 59
    edited January 2
    16 GB of VRAM isn't enough? Wow!
    Indeed, CPU fallback is disabled (though I've apparently always managed without it, even in more complex scenes, as this error only occurred today).
    What's interesting is that I'm not trying to render a complex scene, but just a single product:
    - NEOFF Artemis-13 TLT Medical Transport (https://www.daz3d.com/neoff-artemis-13-tlt-medical-transport-poses-and-camera-anchor), just the Module without any extras, characters, background, etc
    There must be something wrong with the product. I'll enable fallback as a precaution and try rendering a different object, because for the past few hours I've been foolishly trying to render only this one product (without a control product).
    Post edited by schlumpenhuber on
    edited January 2
    Update:
    The file in question still isn't rendering... Something seems to be seriously wrong with the product itself.
    Other things are rendering, but now I'm experiencing a new phenomenon (presumably due to all this messing around).
    If I use the Spot Render Tool, everything renders as usual.
    But if I use the Render button, a tiny thumbnail is rendered. What could I have changed to cause this result? Any ideas? I'm getting a bit frustrated...
    1654 x 1123 - 435K
    16GB should be enough to render that out on it's own but unfortunately I don't have the product myself to check. Do you own iray-memory-assistant, scene-analyzer-organizer-simplifier or scene-optimizer?  Those will give you a quick overview of the subd settings (or estimated faces in the case of scene optimiser) so you can see what in the scene is perhaps causing the issue. Each increment of SubD multiplies the geometry and so it can balloon out of control real fast.  It could be that the product was released with a very high value by mistake?
    schlumpenhuber said:
    Update:
    What is the Pixel Size listed under the General section of the Render Settings tab? Has that accidentally been changed to 64x64 or something?
    I actually just bought the scene optimizer, but I haven't used it yet.
    It's certainly a good approach that I'll try out, so thanks a lot for your help.
    Any further thoughts on the postage-stamp-sized render image described in the last post?
    Update:
    I’ll check this in a moment...
    Update:
    That was it!
    Thank you so much for your help!
    No problem, glad to help :)
    Also, Scene Optimiser does list SubD of all objects in the scene - it's under the "Mesh Resolutions" tab at the top that I have never noticed before - another reason it's good to help others as it also helps me learn more myself :P
