MMX Gen9 clones: save library ref or save geometry?
Hi, question on Mattimanx' Clones for G9: when I load props onto that, will it, like autofitted props from other generations before, save as new geometry (which can take considerable amounts of time, I had simple scenes that took a full minute to save with 2 G3 items autofitted to G8) or will that allow to make a prop reference like any other prop?
  • felisfelis Posts: 6,600
    If you autofit something it is considered a new object. And if that is not saved as such, it will be saved in the scene file and therefore take longer.
    Usual recommandation is to first save as a new item, and then when you save the scene file, it will reference the saved object(s) like other clothing item or whatever.
  • pixelquackpixelquack Posts: 435
    Save as prop, subset, ..?
    Still, this goes for props on the clones, too, or will the clone act as a G9 figure?
    What kind of clone are you talking of?
    That is for autofitting clothing. After autofitting you should save as Figure/Prop asset, unless it is intended as a onetime use.
