[Solved]Changed Install Location. Plugins and Render are causing errors
murf_2006_921bf95f18
As noted I moved my Daz3D location due to a hard disk failure. Now when I render to a preview window the program can't create it's own "r.png" to save/show results. The face transfer plugin also tries to create temp folders for morphs and textures in the old location, resulting in a complete failure. Will someone please point me to maybe an ".ini" location [or whatever I need to update] that will let Daz3D know how to find it's new default directories?
I've been searching for solutions with zero results so far.
Post edited by murf_2006_921bf95f18 on
Those go in the Temp folder, the location of which can be set in Edit>Preferences.
Thanks Richard. The directory setting was already set properly but wasn't working. It started working after I set it to the users/me/appdata/roaming section owned by Daz 3D.
Many thanks for pointing me there.
