G9 Nipples
 New to working with G9 but I have noticed when I attempt to adjust the nipples any adjustment translates as being a pointy con where the nipple should have shape. Am I not doing something or are others having the same issue? Thanks in advance
  • felisfelis Posts: 6,529
    The nipples on G9 are HD morphs. So you must dial a nipple morph, and then make sure your viewport has a high enough subD, to see them in viewport.
  • omvendtomvendt Posts: 182
    Also, they will look different when you render
  • crosswindcrosswind Posts: 10,289
    As default, G9's View SubD Level is 1, Render SubD Level is 3, change the former to 3 if you want to get the same looking of nipples.
    Instead, use G9 nipples geo-graft products that can bring you much better looking with various shapes.
