Where can I get a shirt like this?
Lantern
I'm looking for a sleeveless shirt like the one Reze wears in the anime Chainsaw Man, but I can't find one that's similar.
Does anyone know of a model in Daz Studio that matches the style I'm looking for? I would really appreciate it.
Post edited by Lantern on
I can't give you an exact answer but no-one else can find one then you can probably bodge it as a last resort? Using a normal shirt you could hiding the mesh/surfaces that makes up the sleeves - either actually or via a custom opacity cutout. If the mesh allows, you could perhaps improve that by actualy removing the mesh and using the thickener plugin to make the new edge look less sharp and weird. Alternatively, throw a normal vest on the model and then a shirt on top but hide everything other than the collar - maybe a bit easier but would not have the button seam most likely.
Some collared blouses:
https://www.daz3d.com/mdu-dforce-blouse-for-genesis-8-and-81-females
https://www.daz3d.com/urban-elegance-outfit-set-for-genesis-9
Sleeves can probabaly be hidden, but their edges won't look hemmed.
Similar style tie, but it might be too thick and gaudy:
https://www.daz3d.com/dforce-sweet-chaoz-outfit-for-genesis-8-and-81-females
Could https://www.daz3d.com/teen-kitty-outfit-for-genesis-8-female-s or its texture set, https://www.daz3d.com/teen-kitty-outfit-textures help you get the look you need? You would just have to add a tie from something or make a tie from a string prop?
I have found a bow, but it is a bit thick, not sure if it will work for you. https://www.daz3d.com/dforce-office-outfit-for-genesis-8-female-s
@MMaxxx I found an outfit with a better tie, but still not a perfect match, but it might work for you.
dForce K-Pop Girls Outfits for Genesis 8 Female(s) | Daz 3D
I've read suggestions like that somewhere, but I don't know how to do it. How can I hide the sleeves?
Thank you very much for the suggestions, they are quite good.
Select them with the Geometry Editor, right-click>Geometry Assignment>Cretae Group from Selected. Switch to the Joint Editor, right-click>Create>Create Child Bone (it doesn't matter which bone, or even the whole figure, you have selected). In the Tool Settings pane make the group you created the Selection Group for the new bone (top-right of the Tool Settings pane). Now turning off the visibility of the bone will hide the sleeves. You can also use a Conditional graft, Mada has posted a video on this
dForce Yuna Style Outfit for Genesis 8 Females | Daz 3D
This would be perfect!! I own it and just checked it.
The blouse and tie are together, however separate from the vest!
This model is incredible, thank you very much :D
By any chance, do you know how I can fix this so it doesn't look like this?
The shirt has an cutout oppacity map or value lower than one, and that handles openGL not so good.
If you render it should be fine.
