Arranging tabs in floating docks drives me insane
I had to replace a monitor, Windows changed screen order, my workspace layout I only touch every few month doesn't work anymore, I lost a complete dock with 10 tabs or so.
There is a dock with tabs I have no recollection of ever creating but since it is there I'm willing to reuse it and save a new layout, but: I cannot change tab order or remove tabs from that dock.
Pointers appreciated.
  • pixelquackpixelquack Posts: 419
    edited December 2025
    Switching off one "off screen pane group" miraculously got me the missing dock back on one of the screens, I saved that, but now I cannot change the tab order, I had do re-add "Scene", now it's on the ast position. Any way to edit this?
    Post edited by pixelquack on
  • Is Window>Workspace>Lock Docking/Undocking checked?
  • Yes.
  • The only tab that's not named Dz<tab>Pane is "Scene", that is named "DzHierarchyPane". That figured I got my layout together editing the user layout dsx file.
  • pixelquack said:
    Yes.
    That will stop you from dragging and droping panes, then.
  • Yes, it does rather.
  • More woes: monitor disconnected, floating dock disappeared, made it re-appear by trick: Window->Workspace->Off Screen Pane Tab Groups, uncheck one, check again, pops up in one of the monitors.
    But so far moved up that the top edge is still off screen, so I cannot move it.
    I'll edit the workspace file, too, but really, that's just not good at all.
    Is there a key shortcut to activate the move function?
  • Off Screen Pane Groups should centre the panes - have you tried running it again after undocking a pane (which is what close/open does in effect)?
  • Yes, and it came out at a position "-60" in the dsx file. I manually editied that to 0, then reloading the workspace did it.
    (By the way, can one have a key shortcut "load latest saved workspace layout" somehow or change the default workspace Studio loads?)
  • By default DS stores the session layout (the current state) on exit and loads that on launch, it isn't reloading a named layout. However, the command line can be used to edit that behaviour http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/tech_articles/command_line_options/start and a script could load a layout.
    Multiple Instances issue, I kept some open. Gonna start a fresh set. Edit: fixed.
