My g8 models look weird
Why do my Genesis 8/8.1 female models look like this? Before anyone asks, this is the base 8.1 female model. No added morphs, no hidden properties. Just the default base model. And on top of that, any morph I use with them either looks funky or breaks entirely.
4000 x 3000 - 3M
  • Rather than try to take a photo of your screen you could use the built-in screen capture tool (e.g. the Snipping Tool/Snip and Sketch for WIndows).
    Most likely a character or morph you recently installed has a non-zero default value, so its shape loading already aplied. Edit>Figure>Zero Shape should restore the default, then if you go to File>Save As>Support Assets>Save Modified Assets (not Modifier Asset) a dialogue will pop-up listing all the affected shapes; if you can spot the cuplrit you can either uncheck everything else and save that (you don't want to save everything as some thinsg may be non-zero by design) or you can just make a note of the shapes affected and then test each in turn on a freshly loaded figure by zeroing them individually until the unwanted shape goes away.  Either way, check to see if the product has an update
    Regardless of what you do on ypur instalaltion, please report the issues to Daz (if it is a Daz store product) or the the maker (freebies and content from other stores).
