Push Up Animation
hi_7c5f6197hi_7c5f6197 Posts: 11
edited March 2016 in Daz Studio Discussion
Hi all,
I'm a newbie. Plz help me this case.
I want to do this animation: https://youtu.be/5eSM88TFzAs
I researched very much but I couldn't find out how to do that.
The hands always move between 2 actions up and down eventhough I pinned it by ActivePose Tool and Universal Tool, I also used the LockPartBody Script but it didn't work too.
Beside that, when I pin the hands and put the body up or down, it will mess and doesn't get the pose as I want.
Plz show me how I can do the push-up animation as demo.
Thank you so much!
572 x 543 - 73K
  • Richard HaseltineRichard Haseltine Posts: 111,779
    Moved to Daz Studio Discussion as it is about DS, not Poser.
    I would suggest getting the arms into the starting position using the regular posing tools, then use the Universal Tool ot Active Pose to carry out the up-down movement. Having the starting position right should ensure there is enough play in the relevant joints.
  • defuser2002defuser2002 Posts: 61
    edited March 2016
    Here is a link to a possible pushup file on sharecg:
    http://www.sharecg.com/v/53379/gallery/21/daz-studio/10-times-pushup-animated-pose
    It does work in DazStudio. :)
    Post edited by defuser2002 on
  • Thanks all for your reply.
    I tried http://www.sharecg.com/v/53379/gallery/21/daz-studio/10-times-pushup-animated-pose but the hand also move a little bit :(
  • RuphussRuphuss Posts: 2,631
    edited March 2016
    i would like to see it in motion
    can you upload a video ?
    edit:
    tried it myself
    yes the hands are trembling
    now
    create a pose preset on frame 0
    one at frame 9
    zero the pose of your V4/M4
    look for casuals autolimb2015/keeporient at freebe section
    pose with your saved presets at 0 and where you want it to end the second one
    use autolimb on feet and hand
    use keeporient for correction
    no trembling at all
    i just tried it
    good luck
    Post edited by Ruphuss on
  • selias19selias19 Posts: 254
    MCasual has a lot of scripts for animators. Maybe you can find something suitable there?
    Pin me down perhaps? https://sites.google.com/site/mcasualsdazscripts/pinmedown-for-ds2-3
    Here is his site https://sites.google.com/site/mcasualsdazscripts/
    I don't do animation so I cannot help you.
  • Fixme12Fixme12 Posts: 589
    edited March 2016
    Hi all,
    Thank you so much!
    Hi, as long the inverse kinematcis are not fixed in dazstudio, this job is very difficult to do without wasting time. You still keep moving hand or feet movements you don't want and spend lot's of wasted time to tweak it.
    You can try to import the daz rig into "akeytsu", i've seen good working combination between dazstudio > 3dxchange > akeytsu
    akeytsu is some very good indie animationtool in beta.
    Post edited by Fixme12 on
    hi fixme
    how much money for this ?
  • nonesuch00nonesuch00 Posts: 18,878
    It is $79 for indie beta (make less than $200K per year) but you can get the Beta for free until it expires.
    and 3dexchange ?
  • Thanks all for your help!
    I'll try all and show you how it works :)
    edit:
    tried it myself
    now
    one at frame 9
    no trembling at all
    i just tried it
    good luck
    Hi Ruphuss,
    I find out autolimb2015, but what is keeporient?
    I just learn this software several weeks so can you show me more detail?
    Thank you so much!
  • hphoenix said:
    Thank you hphoenix!
    I'll try it :)
  • Hi all,
    I want to do the pose for push up movement and I can't make the down pose of push up movement.
    It always mess. If I make it seperately - it's ok. But when I make it from up to down - it's terrible as attach file.
    Plz help me!
    572 x 543 - 73K
  • Hi hphoenix,
    I don't understand the example of mcjKeepOrient. How I can do as example? I tried but didn't succeed :(
  • Eureka!!!
    Thank you a lot! I did it.
    It works well by using mcjKeepOrient and mcjAutoLimb2015.
    Thank you again!
    Merged threads - and please don't post Daz Studio questions in Poser Discussion.
