Help Running Two Daz versions at the Same Time
I use two versions of Daz for different types of work with two different libraries and I'm currently able to run Daz 4.12 & 4.23 at the same time without issue. I plan to update my Daz 4.12 to 4.16 but I know from previous experience it has failed to run 4.16 & 4.23 at the same time. I was hoping someone might know how I can run these two at the same time.
You can only run different Build at the same time, i.e. DS 4.16 General Release and 4.23 Public Build.
Unless you use a version new enough to support instancing, which you apparently do inteng to: Daz Studio Pro 4.12 - instances
