Neck proportions and hair fitting
In Daz3D, when I change the neck proportions, hairstyles stop fitting the head properly — they shift by exactly the amount of the change. Using "Fit To" or even removing and re-attaching the hairstyle doesn’t help.
What can I do?
Thanks.
  • felisfelis Posts: 6,602
    edited December 2025
    Which character (generation)?
    And which method to change the neck length?
    And which hair?
    Post edited by felis on
  • crosswindcrosswind Posts: 10,344
    More likely the issue comes from Auto Follow....  You can try: in Parameters pane, Show Hidden Properties.... Select the hair, check if you can find the hidden property of neck proportion, then zero it. See if that helps.
    You also can use Rigidity Group to clear the generated morphs of Auto Follow properties... but that'll require more effort.
    Or, you can just parent the hair to the figure's head node and tweak its Transforms.
    Thank you, it worked!
