Cant install GOZ
When I try to install Goz I get the following message.
527 x 134 - 61K
  • fixmypcmikefixmypcmike Posts: 19,738
    Are you installing with the standalone installer?  Was DS installed the same way?
  • AngelAngel Posts: 1,204
    stand alone, and no
  • Richard HaseltineRichard Haseltine Posts: 111,908
    If you installed DS using the stand-alone installer then DIM won't know where it is. In DIM click the gear icon at top-right, then go to the Applications tab, if DS isn't there click the + button at the bottom of the pane and set the details for DS (name, bits, version and the path via the ... button). After doing that you should be able to install GoZ.
    And vice versa, if you installed DS with DIM then you should install GoZ the same way.
