Does Daz Studio support material instancing?
Is it possible in Daz Studio to have one material shared by several objects, so that when I change its parameters (for example, the color), the change affects all of those objects at once?
In other words, does Daz Studio support “material instancing” like this?
  • JalnorJalnor Posts: 15
    This would be really handy. Commenting to bump, in case anyone ever answers any queries in this section these days.
    If it's not currently a feature, I hope Daz will consider adding it.
  • felisfelis Posts: 6,563
    To my knowledge no. When applying a material, you have individual setting in the surface pane. And the only external part is images. Of course you can update the content of an image and it will hit all users of it.
    You could probably create a script, that runs through all surfaces, and update those with a specific names, but the use might be limited.
    Regarding bump) not sure what you are asking. If you look in the surface tab, there is a bump channel.
