Valenia 9 HD Add-On Bundle
Brian&AliciaBrian&Alicia Posts: 285
i think there is a problem with the skin and texture packs. the add on bundle says genesis 9 the compatable figure. but loading up the scales or texture packs it just gives errors, and nothing is working right. also i'm not happy that the wing and tail texture add ons are seperate from the scale texture pack. seems you have to have the main character it's made for. for any of it to work without errors. i was under the impression it would work with genisis 9. now i'm taped out on spending money and need to wait to even use the main reason i purchased anything today. and now i can't even use it. instead of putting genesis 9 in the compatability section, maybe put the charater that's actually required for it to work properly. i was going to call off thanksgiving to create with this. now i have to go be around...people...
  • Moved to Technical Help as it is not a Daz Studio application topic.
    What errors are you getting, and how did you install?
    I managed to figure this out. I was loading the "persona" (which never seen that label before) so kinda confused me. Then the shapes were in a new folder called "shaping" so I didn't find everything for it right away. And just thought the persona was it for the scales. But all good now. I found all the newly added folders for it. Instead of it going to the usual spots.
