converting G3M -> G8M
Hi all,
For a scene I'm going to be doing shortly I need to put a G8M into a hospital gown, so far the only one I've found is https://www.daz3d.com/hospital-wear-for-genesis-3-male-s-and-female-s any suggestions on making it look good on a G8M?
thanks!
  • crosswindcrosswind Posts: 10,347
    edited November 2025
    I've used the wear on G8F/G8M for a couple of times. Auto Fit would do the job. (or go for the way of changing Preferred Base in Scene Identification... https://youtu.be/9WwTQkouIvc?si=LAaizJsHZnjGmAHp)
    Besides, this item has no dForce capability... You have to tweak its shape with posed figure (the vendor provided some morphs for certain Pose products...) or add dForce modifier yourself. We ever discussed about adding dForce on it in this thread : https://www.daz3d.com/forums/discussion/672781/
    We used G8F as the exmaple but the way is almost the same on a G8M. You may find it helpful ~~
    Post edited by crosswind on
