Cannot apply G8 pose to G9 figure using Ctrl+Alt+P
I previously did this. I know I did. And Google search still suggests this although it also suggests Edit > Figure > Pose ... which no longer exists either. I'm am trying in Daz Studio Alpha 6.25.2025.30407 and in Daz Studio 4.24.0.3.
Is there a trick I've forgotten?
Steps:
  1. Select Genesis 9 Figure.
  2. Select a Genesis 8 Female pose.
  3. Hit Ctrl+Alt+P. Nothing happens. Does not register as command in the Undo register.
  4. Go to menu Edit > Figure > ... look for Pose ... does not exist.
I've used the Bone Minions from Riversoft Art, and those seem fine but require extra steps in the process to add the bones, apply to the bones, remove the bones.
  • crosswindcrosswind Posts: 10,347
    Ctrl Alt + P comes from Pose Converter binded with Premier tier. Is your Premier membership validated via Daz Connect ?
    If Premier was not successfully validated, Pose Converter as well as its shortcut wouldn't work at all ~
  • Maybe DS wasn't properly connected? I restarted DS Alpha, checked that it recognized me as Premier, and the Pose Converter works. I did nothing else other than restart DS. frown
    If I can reproduce, then I'll submit as a bug, but I don't know steps to reproduce this.
