CMS not starting and ignoring me
Ryselle-RyssaRyselle-Ryssa Posts: 159
Hi!
I have a fresh installation of DAZ Studio on a new Windows 11 PC and cannot get Smart Content to work.
DAZ Studio 2025 (6.25) keeps showing the error:
"Resource error: A valid PostgreSQL CMS connection could not be established."
What I see / What is happening
  • In Install Manager → Advanced Settings → CMS Settings, the Cluster Directory is set to:
    C:/Users/me/AppData/Roaming/DAZ 3D/cms
  • That directory contains a cmscfg.json with:
        "DatabaseClusterPath" : "C:\\Users\\<me>\\AppData\\Roaming\\DAZ 3D\\cms",
        "Port" : 17237
Solutions tried
  • I opened port 17237 on the firewall, but it didn’t help.
  • When clicking the CMS icon (the three stacked disks) in Install Manager and telling it to start the CMS, nothing happens.
    The log only says:
    “Error Starting CMS – Cannot be started by client.”
  • Attempts to use the old CMS from the previous, working, installation on old pc
    I moved the old drive from my previous machine, which contained a working CMS folder:
    R:/Other/DAZ_CMS
  • I tried to point Install Manager to this folder, but:
    • It never saves the changed path — it always snaps back to the default AppData path.
    • Editing the path manually inside cmscfg.json also does nothing.
    • Copying the old CMS folder contents into the new one also does nothing
Result
  • The error stays the same no matter what I try: DAZ Studio cannot connect to PostgreSQL CMS and Smart Content is unavailable.
Thank you for any help in advance ♥
Post edited by Ryselle-Ryssa on
  • Is the actual application, PostgreSQL, installed? In the same version (32/64 bit, ideally the same release channel) as on your previous system.
  • Hi! Yes, it was installed, but double, one from the "normal" version, one from the alpha. And somehow this collided. After removing all DAZ versions except die Alpha, it now works fine :-)
  • Usually installing one version of PostgreSQL will remove any others, so that is odd.
  • I sadly cannot explain what was going on under the hood of the system, just that it somehow solved the problem ^^
