DTU bridge for UE 5.7?
Is there a working update coming for DTU for UE 5.7 yet? I saw one on GitHub but when I tried it is just says it's not written for that version?????
I have projects that require the dtu to be working on the latest version of unreal so this is a major problem for me
Yes ~ ~ check David's update in here: https://github.com/David-Vodhanel/DazToUnreal/releases/tag/v5.7.0.519
@crosswind Did You Check this yourself before posting that link because that version throws this error in 5.7
The following modules are missing or built with a different engine version:
DazToUnreal
Engine modules cannot be compiled at runtime. Please build through your IDE.
So NO it does not work
The Fab store version also has not been updated since : June 12 2025
Sorry, I had no chance to test it. That's for 5.7 early access.
You may contact David if the version didn't work to you.
How do we contact him?
You may approach him via DISCORD : https://discord.gg/tVcDBMF
is that the best way to ask him to update it? instead of github?
Hi, I'm adding some documentation here since it was hard for me to find.
How to install DazToUnreal v5.7.0.521 to UnrealEngine5.7.2 using the OnlineInstaller v1.0.0.6.
:warning:Remember to run OnlineInstaller with admin permissions.
These are the binary versions that I used.
Installing the DazToUnreal v5.7.0.521
https://github.com/David-Vodhanel/DazToUnreal/releases/tag/v5.7.0.521
using OnlineInstaller v1.0.0.6 ( run with admin permissions)
https://github.com/David-Vodhanel/DazToUnrealOnlineInstaller/releases/tag/v1.0.0.6
