[Solved] More Problems Creating Hair Morphs
Lucky13guyLucky13guy Posts: 92
Yup, I'm having more problems creating hair morphs. Last time I had issues with OOT's Dark Ponytail for G8F, but @crosswind was kind enough to teach me the trick about deleting unused verts before export, and I was good to go from there.
This time, I'm working with OOT's Zola hair for G8F. I pulled the mesh into Blender, created my morph, then went to load it and got a "Geometry did not match" error. Kind of annoying, since I spent a good hour getting the morph perfect, but whatever. The problem is, when I tried deleting unused verts on the Zola hair, I got a popup saying there are no unused verts. So now I'm stumped. I've verified that I'm exporting the mesh at base resolution, so that's not the problem. Does anyone have any ideas why I can't morph this hair?
Thanks in advance!
Post edited by Lucky13guy on
  • crosswindcrosswind Posts: 10,351
    Ah, this time the culprit is different. You can expand all sub-nodes under Zola Hair, you'll find there's a hidden node : Hairknot. So you have to uncheck Ignore Invisible Node when exporting the hair to OBJ. (Screenshot 1)
    Then it'll work ~~
    510 x 612 - 51K
    Then it'll work ~~
    That did it. Thanks again!
    No problem !
