LOST ALL MY CONTENT?
ISIKOLISIKOL Posts: 386
Hello there...please forgive me for been not familiar with Daz studio workarounds...after i installed 4.9 i lost all the content that used to be shown on the left...
now it gives me a message that is been showing on the attached image...
i have turned antivirus and firewall off...any idea what is the problem? thanks in advance...
2555 x 1431 - 655K
    Have you logged on the one time you need to to finish up the 4.9?  You only have to do it once and then you never have to do it again if you don't want to.
  • Richard HaseltineRichard Haseltine Posts: 111,390
    Which firewall are you using?
  • DAZ_RawbDAZ_Rawb Posts: 817
    A common misconception, 4.9 actually never needs to login unless you want to install products through Daz Connect.
  • VhardamisVhardamis Posts: 576
    Also check that 4.9 is pathed to the correct folders to find said content, especially if you had custom paths in your last version.
    I would make sure that both the Postgresql, and Postgresql Valentina Conversion packages are installed through DIM (do the postgres one first, then the valentina conversion one).
    If those are both there then try restarting Daz Studio. Sometimes when you shut down DIM and start up Daz Studio right after each other Postgres gets the message to shut down after Daz Studio has checked to see if it is running, so what happens is that Daz Studio starts up and doesn't think it has to start Postgres because it is already running even though all it is doing is shutting down.
