Is it possible to save View SubD Level and Render SubD Level as a preset?
SnowSultan
in The Commons
I looked through all of the options when trying to save a Properties preset, but those two parameters do not seem to be included in the available choices. Can they not be saved as a preset? I'd like to be able to quickly switch SubD levels with a button rather than going through Scene Optimizer or other plugins. Thanks.
Unfortunately SubD properties are not included in the saving options of any Presets...
You have to set them by using Daz Scripts ~~ Check this : http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/properties/node_properties/start
Then use the clause like : findProperty("SubDIALevel"), setValue(your desired subDLevel), etc.
There're some Scripts within certain products that can get job done, check if you have them by: go to DS > Smart Content, filter by: "key::subd, you might be able to find some... Usually they're not encrypted, you can change the subd level values in Script IDE ~~
Thanks for the answer. I don't need it that badly to mess with scripting, haha. ;)
Does saving the figures as "scene subset" save the subd data? It should. But it will take longer to load than a material only duf.
