shape preset: what does it do and what not?
Reading the Dial Fusion description I come across: "...Dial Fusion also remembers the figure's scale, which a shape preset doesn't."
This explains something, I saved quite a few variations on work in progress characters when I suddenly notices a character was a different height then what I saved in a subset.
So what exaclty are shape presets supposed to do, and what not?
  • LeanaLeana Posts: 13,631
    They save setting for parameters which appear in the shaping tab, and only those.
    Scale is a "posing" parameter not "shaping" so it doesn't get saved.
  • A Shaping preset saves properties with the type Modifier/Shape. If you want to add other types use a Properties preset, which has tabs for different types of property that can be enabled and disabled.
  • pixelquackpixelquack Posts: 442
    edited November 2025
    So if I want to start with a base genesis and end up with a character I morphed together in another instance I need a shape preset *and* a properties set.
    So Dial Fusion solves all that, it seems.
    Post edited by pixelquack on
  • A Properties preset can save shaping and posing properties - it can't load a new item, however, the way a Character oe Wearables preset can.
