Daz studio DAE Import bug?
Khai-J-BachKhai-J-Bach Posts: 163
edited December 2021 in Technical Help (nuts n bolts)
nt
Post edited by Khai-J-Bach on
  • Richard HaseltineRichard Haseltine Posts: 111,935
    Sounds as if the way the mesh is split as a result is causing DS to see end-of-file (does it lose the UVs, assuming any are assigned?) If you have a sample you could post - a simple cube with coloured bands of faces for example - someone may be able to spot the issue.
    There's a couple of other things that could be up, too...but like Richard said, without seeing it, its hard to see what's up.
  • I have run into the same problem and I think the fault is with SketchUp's export. When I tried to use the dae export I get nothing, zip-zero-naught except for place holders. There is nothing visible at all even though it is listed in scene content.
    But when I import a dae from other sources, it has always worked fine.
  • Khai-J-BachKhai-J-Bach Posts: 163
    nt
