Wrinkled Photoshoot Floor Covering?
FJM1977FJM1977 Posts: 358
edited October 2025 in Product Suggestions
Is there anything that could be used for a wrinkled floor covering for photoshoots?
(I know that usually you try to reduce wrinkles so they don't show up and ruin the photo, but I have seen some photoshoots that incorporate the wrinkles)
Examples:
https://img.pikbest.com/wp/202343/linen-texture-wrinkled-dark-black-cloth-a-crumpled-of-textile_9983556.jpg
https://st4.depositphotos.com/36844668/38816/i/450/depositphotos_388165056-stock-photo-background-texture-black-cloth-abstract.jpg
529 x 553 - 42K
920 x 915 - 112K
846 x 864 - 142K
884 x 884 - 163K
Post edited by FJM1977 on
  • NorthOf45NorthOf45 Posts: 5,941
    Try dForce Studio Drapery which has some morphable ground sheets.
  • FJM1977FJM1977 Posts: 358
    Thank you! As The Cars once said "Just what I needed!"
  • You could try making one with dforce.
    Make a plane with a reasonable number of divisions in it to act as the floor - I used a 10m plane with 50 divisions.
    Make another to act as the sheet, the more divisions the better - I tried a 3m plane with 200 divisions. Give this sheet a dforce dynamic surface modifier.
    Position the sheet a metre above the floor, and tilt it slightly in X and Z directions and let the dforce simulation run. You can experiment with tilting it more or dropping it further to get more creases - I just did something quickly as a proof of concept.
    653 x 487 - 43K
