How to make object's axes follow the object?
How do I change a prop so that the xyz axes stay local to the object, instead of being tied to the world axes? So that they rotate with the object? I gather that for some reason this is beyond DS, so how do I change it? I'll use whatever software I have to. I can't put up with the way rotation works any more.
  • Richard HaseltineRichard Haseltine Posts: 111,831
    Go to the Tool Settings pane and adjust the option at the top, just under the tool name button.
    https://sites.google.com/site/mcasualsdazscripts2/   (mcasual script home)
    https://sites.google.com/site/mcasualsdazscripts3/mcjchangeorientation  (tool)
    even though you change tool setting,,  It not correspond to the parameter tab,,
    it need to rotate by universal  tool, or rotate tool,. that means, when I need to rotate obj as local axis,, with precise value, very un-useful.
    eg can you easy rotate the obj,, with 33 by local ,X axis, then rot the obj with current local Y 25 easy?  though tweak and play with Snapping,, it really difficult for me.
    there is no box,, which I can input ,, local rotation value still sad
    (the OP quesiton is actually ,, what I reportted and asked as futrure request,, to rotate obj with local  axis,, by input values, 4 years before,,)
  • JQPJQP Posts: 527
    Oy, I'm an idiot. I either forgot or didn't realize (probably forgot - I seem to remember making a thread like this years ago) that while universal tool has this annoying behavior, the rotate tool does not. So I was all het up over nothing.
  • JQPJQP Posts: 527
    Richard, wow, that's good to know, thanks. You written DS for Dummies yet?
