Materials of a DzMaterialSelectionSet?
I can get the materials of a shape via DzShape.getNumMaterials().
I can get the selection sets of a shape via DzShape.getMaterialSelectionSets() (recursive).
But how to get the materials assigned to a selection set (DzMaterialSelectionSet.getMaterials(oShape) will return all materials of the shape, not only the assigned)?
I work with DS 4.24. Any ideas?
  • If I understand what you're asking, it ounds like you want to iterate over all the materials in the shape. Did you try using the getMaterial() method?
    Something like this?
    var aMaterials = []
    for (var x = 0; x < shape.getNumMaterials(); x++) {
      aMaterials.push (shape.getMaterial(x));
  • kabexefkabexef Posts: 96
    var aMaterials = []
    Thanks for reply. What I need is information about which material is assigned to which selection set.
  • Ah. Sorry, I misread your ask.
    So out of curiosity, I don't see the DzShape.getMaterialSelectionSets() in the API docs? Is that an undocumented method?
    Yes, it is.
  • OmnifluxOmniflux Posts: 439
    DzMaterialSelectionSets is undocumented and therefore subject to change...
    DzMaterialSelectionSets.getMaterials(DzShape*, bool)
    The boolean parameter appears to be whether or not to recurse, and defaults to true if not specified.
    Using Genesis 8.1 Female:
    var oShape = Scene.getPrimarySelection().getObject().getCurrentShape();
    var oMaterialSelectionSets = oShape.getMaterialSelectionSets();
    for (var i = 0; i < oMaterialSelectionSets.getNumChildren(); i++)
    	var oMaterialSelectionSet = oMaterialSelectionSets.getChild(i);
    	var oMaterials = oMaterialSelectionSet.getMaterials(oShape, false);
    	print (oMaterialSelectionSet.name);
    	oMaterials.forEach(function(x)
    		print (" " + x.name);
    Executing Script...
    Default Templates
    Skin
     Body
     Face
     Ears
     Legs
     EyeSocket
     Arms
     Head
    Nails
     Fingernails
     Toenails
    Skin-Lips-Nails
     Body
     Face
     Lips
     Ears
     Legs
     EyeSocket
     Arms
     Fingernails
     Toenails
     Head
    Genesis 8 Legacy
    Result:
    Script executed in 0 secs 8 msecs.
    Executing Script...
    Default Templates
    Skin
     Body
     Face
     Ears
     Legs
     EyeSocket
     Arms
     Head
    Nails
     Fingernails
     Toenails
    Skin-Lips-Nails
     Body
     Face
     Lips
     Ears
     Legs
     EyeSocket
     Arms
     Fingernails
     Toenails
     Head
    Genesis 8 Legacy
    Result:
    Thanks a lot. Works well also with Genesis 9.
