Weird "Can't Render" behavior
So I got the attached popup "Unable to render. Renderer is in use."
I look in the log. Nothing.
I set drawstyle to IRAY. The viewport switches to IRAY draw style without issue.
Attempt to Render. Unable to render.
Set the viewport back to Texture Shading. It does so
Check the log. Other than the IRAY viewport render stuff. There's nothing. Hit save a few times to clear the logging buffer.
2025-10-18 12:50:43.521 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 4090): 250 iterations, 1.772s init, 29.865s render (((This is the timestamp from when I put the viewport back into Texture Shading mode)))
2025-10-18 12:51:14.167 [INFO] :: Saved image: E:\DAZ3D\Pinups\004.tip.png (((This was after an attempt to render failed.)))
2025-10-18 12:52:12.812 [INFO] :: Saved image: E:\DAZ3D\Pinups\004.tip.png (((This was after a second attempt to render failed.)))
There is no error in the log at all about the renderer being in use.
I expect I need to restart Daz. But is this normal? I've never seen this before.
