Viewport disappears with any movement..
elhectroelhectro Posts: 69
edited October 2025 in Daz Studio Discussion
Hi, I'm experiencing a strange thing. The viewport goes white, or black, no image displayed, but everything is selectable (figures, icons, objects). Rendering works OK. This happened after daz closed during a rendering, perhaps could have been a black out. Don't know for sure, as I left it rendering an animation. The only way to make it work is reinstalling the Nvidia driver (used the newest Studio driver from offical Nvidia app)... restarting DAZ and PC don't work. But, if I minimize DAZ, or close it, it goes blank as in the image when I maximize it again, or black when I reopen. So, I have to reinstall the driver again to make it visible. It's a destkop, windows 11, 3060 Nvidia. Any ideas why this is happening? For the record, I've been using this PC for a year and a half, and have worked normally, so it shouldn't be a config issue.. Thanks
1920 x 1080 - 1M
Post edited by elhectro on
  • IceCrMnIceCrMn Posts: 2,334
    If you have to keep reinstalling your GPU driver I am assuming that either Windows 11 is installing it's own version
    which is seldom a good choice
    or yours was somehow corrupted after the crash you described.
    I'd start with disabling GPU driver updates in Windows update
    second I'd do a clean install of the newest GPU driver after using DDU to completely remove the old driver
    DDU link
    https://www.guru3d.com/download/display-driver-uninstaller-download/
    I have the same GPU and I see the same viewport behavior when I'm doing renders with the viewport turning white if I minimize/restore Studio while it's rendering, but mine seems to correct itself after a few moments and items in the viewport become visible again. I usually just disregard this when it happens because the render is working fine and I can't do anything with Studio anyway while it renders.
    I'm not sure how desktop sharing will effect Studio. I've never tried to share my desktop while rendering and things like that. Are you sharing when this happens?
    Anyway, I hope this helps, if not report back and maybe others will have some insight.
