No HUD no interface nothing
Hey!
Since I updated to Windows 11 I don't see anymore my interface/icon/scenes
Tried to update Daz to 4.24 to see if this would fix my issue but nothing changed (see attached) (+ tried to uninstall/reinstall multiple time aswell)
Everything was working perfectly when I was on Windows 10 with Daz 4.23
Anyone having the same problem ?
1912 x 1032 - 29K
  • I switched to Windows 11 yesterday without issue, as have others, so I don't think it is that that caused the problem - but it appears to be an issue with the session layout files, which store the menus, panes, toolbars and so on when DS closes and restore them when it opens. You don't want to lose your custom actions and so on so I would suggest Window>Workspace>Customise, then click the Import button at the bottom of the dialogue and select Layouts; a file selector will open from which you can select a layout you saved or one of the standard layouts. You can also just use Window>Panes(Tabs) to enable the panes you want and then drag them where you want (drag by the top to move a group, which can then be docked at top/bottom/sides when a line of highlight colour appears, or by the tab, to add them to an existing group by dropping the tab in the well with the existing tabs).
