"Clean" a UV?
RevokedRevenantRevokedRevenant Posts: 47
edited October 2025 in Daz Studio Discussion
Greetings,
I have a building, in which i'd like to change the aspect of the floor by applying a shader.
As you can see from the second attached image, after i have applied the shader some unwanted artifacts are showing: that's because the UV of the floor is quite specific (see image 3).
I'm not an expert on UVs, so my question is: is there a way (if that's makes sense) to obtain a "clean" UV? like an UV that let me cover the object in whatever texture/s i want, without placing one part of the texture here, one part there, thus creating the artifacts?
I really hope i asked an understandable question wink
Thank You in advance!
857 x 841 - 343K
857 x 841 - 144K
1040 x 983 - 11K
Post edited by RevokedRevenant on
  • felisfelis Posts: 6,604
    You can create a new UV in a modeller, and load the UV into Daz Studio.
    For using it you need to select that UV for this surface.
  • crosswindcrosswind Posts: 10,347
    edited October 2025
    Do you know any modeling software like Blender... and how to unwrap UV to make a new UV layout ? Then a new UV layout can be imported as a UV Set for the floor on which the shader preset can work well.
    Another work around is to replace or just cover the floor with a primitive plane then apply the shader preset to the plane surface... which'll be much easier.
    Post edited by crosswind on
  • Thank you both! I know some basics of Blender (very few actually), so i could follow @crosswind suggestion yes
    I'm gonna search for a simple tutorial on UV unwrapping in Blender
    Thanks again!
    To just change the UV of the floor in blender, go to edit mode, select all the faces of the floor and click UV > unwrap conformal
    That will not change the UV of the rest, but if the floor is it own(s) surfaces that doesn't matter,
  • lilweeplilweep Posts: 2,879
    edited October 2025
    just put a plane over it... (or instead of it)
    Post edited by lilweep on
