Genesis 9 LIE Makeup Scripts Not Executing
SHNSHN Posts: 17
Im using Makeup System - Smokey Classics LIE Makeup for Genesis 9 on different Genesis 9 models but the script just wont excute. I've tried uninstalling & reinstalling, I've used a past discusssion to see if that fix worked, and I've tried seeing if I tried to execute the .dse manually from the file location if it worked. The script will not execute even if I use it on one of the default Genesis 9 models- the only time I get something is if I try running it on the sublayers (ex:tear or mouth) which gives me the no materials found error. Im using Daz Studio 4.24 and have made sure everything is updated. I get no messages, pop ups, or anything on any character views when I double click the script file otherwise.
Post edited by SHN on
  • Richard HaseltineRichard Haseltine Posts: 111,939
    edited October 2025
    How did you install? Have you checked thee nd of the log for errors after trying to run the script (Help>Troubleshooting>View Log File)?
    Edit: actually I have that set, since it came with the Zahira 9 bundle - judging by the log it is using Zahira 9 maps, and I certainly didn't see much chnage other than lip shine when I tried it on a different character.
  • Een applied to Zahara the effect is very subtle, at least for the first version - having done a with and a without render only the lips showed, dimnly, if they were layered with the difference blend mode - it was necessary to apply a levels adjustment to see that yes, the eyelids and face were changed somewhat (and beyond that, the whole face did lighten and then the rest of the figure - possibly as a rsult of the different interactions with light in the face).
  • crosswindcrosswind Posts: 10,351
    Make-up scripts work as expected on my side. I tested a couple of scripts on Victoria 9. They work fine on the character as well as the settings of LIE stacks. (ss1~2)
    However, Remove make-up scripts didn't work 100% correctly.... they didn't reset Metallic Flakes Enable to Off...(ss3)
    I installed the product with DIM ~~
    2560 x 1392 - 3M
    2560 x 1392 - 3M
    2560 x 1392 - 3M
