Is It Possible To Run Daz4.12 Beta And The Latest Non Beta Version? Solved
IceDragonArtIceDragonArt Posts: 12,972
I should know the answer to this but its been more than a couple of years... I have Daz 4.12 Beta running, but am curious if I can load a later version that is not Beta and keep 4.12.  I would like to try a newer version but i've been told that the latest may not work well with my less than newer laptop lol.   I am quite happy with what I have but am curious
  • Yes, that should be safe - settings are not shared and I don't think there would be aby problems with the database (though I would back up first, and export user data too).
  • crosswindcrosswind Posts: 10,249
    Yes, General Release and Public Build (Beta) can be run at the same time. So, you can install the latest DS 4.24 General Release ~~ But better make a backup of your current General Release... just in case.
    I don't think I currently have a general release loaded on this machine
    edited October 2025
    How would I do that?  all of my content is on a separate drive.  Can  I just back up and export data thats on my C drive, the parts that actually run it?
    I also have another external drive, I guess I could just copy the whole thing to that?
    Also when I download it, should i leave that separate drive disconnected?  I have everything in DIM set to go that drive, but 4.12 Beta does have the files that actually run Daz on the C drive.
    Not the content, the database and the user data (non-store entries in the database).
    The database is in the ContentCluster folder (Edit>Preferences?CMS Settings) and should be backed up when nothing is using it (all Daz applications closed).
    To export user data open the Content Library option menu (the lined/"hamburger" button in the top corner or right-click the tab), seelct Content DB Maintenance, check Export User data and  Accept.
    Okay I have copied the content cluster folder to the external drive in a separate fold.  Side note, I apparently have Daz studio 8.1 or something also backed up lol.  I am exporting my user data and then I guess we will give it a go. Thank you!
    Well that seems to have worked perfectly.  Thanks again!
