Premier page says: "Genesis 9 hair now compatible with Genesis 8" - Can't get it to work...
I became a Daz3d Premier customer today in order to use some G9 hairs that doesn't load properly with the auto-fit "Genesis 9 MMX". On this page: https://www.daz3d.com/blog/daz-studio-premier-and-daz-studio-4-23-updates?srsltid=AfmBOopfbWNv4SwvQcyua0-E7LsxPqy0RNqr1VMuq6N6Vj8GLtvpG45Z it says
"Enjoy Genesis 8 auto-fit enhancements, which allow you to use Genesis 9 clothing on your Genesis 8 and 8.1 figures with more accurate fitting. This gives you access to a larger wardrobe without worrying about awkward fits, making your characters even more versatile. Genesis 8 clothing and hair can now fit onto Genesis 9 characters, and for the first time ever, Genesis 9 outfits and hair are now backwards compatible with Genesis 8 and 8.1 figures"
I have installed all premier plugins but i can't load for example dForce Dokidoki Hair to G8F. I click for loading the hair and when promted chose "Genesis 9" but the result is the same as when chosing Genesis 9 MMX.
What am i doing wrong? Do I have to install something more?
  • LeanaLeana Posts: 13,504
    edited October 2025
    Autofit enhancements are not linked to premier plugins, they were an update to Genesis 8 to add a G9 clone. Since you said you have the "Genesis 9" option as well as "Genesis 9 MMX" you seem to have that installed.
    As an automatic conversion process autofit is unfortunately not a perfect process and there are some items it doesn't work that well with.
    Personally for hair I tend to manually position and adjust it and then parent it to the head rather than use autofit.
    Post edited by Leana on
  • Veronica MaggioVeronica Maggio Posts: 50
    edited October 2025
    OK! Thanks Leana!
    Do you load the hair to G8 before adjusting it? How do you avoid Auto-Fit? What are the steps?
    Post edited by Veronica Maggio on
  • Load the hair with nothing seelcted, so it doesn't try to fit to (cancel it if it does try). Parent it to the figure's head. Use the transform tools (Translate/Rotate/Scale) to line the hair up with the head in a natural manner - you can also use dForms/Pushmodifiers/Smoothing Modifiers with collision/Mesh Grabber/Geoemtry Sculptor for fine-tuning.
    OK! Got it! Thanks Richard!
  • Bear in mind that there are many different types of hair, soem are easier to convert (manually adjust or using converters made for clothing) than others.
  • MasterstrokeMasterstroke Posts: 2,497
    That is a pretty unhelpful advise, because the hair is just parented and not conformed.
  • Richard HaseltineRichard Haseltine Posts: 111,390
    edited October 2025
    In which case you don't need to worry about the not fiting part and can reparent (if need be) and continue from there - indeed, few if any converters will help with items that are parented rather than fitted anyway.
