Question about HT dForce Wiggle and Squishy Body for Genesis 8 Female
https://www.daz3d.com/ht-dforce-wiggle-and-squishy-body-for-genesis-8-female
Noticed it doesn't say it's compatible with G8.1F so before buying I'm wondering if that's the case, if so why wouldn't it be, or if it's just a mistake
  • LeanaLeana Posts: 13,560
    I don't have the product so I can't test if it works, but considering that dForce works on surfaces and that torso surface is one of those which was modified in 8.1, it's possible that it wouldn't work directly on 8.1.
  • crosswindcrosswind Posts: 10,322
    edited October 2025
    There's only on Character Preset of G8F with dForce Modifier in the product. You have to:
    1) Firstly save Shader Presets from G8F's Legs and Torso surfaces (Simulation Settings Only). Add dForce Modifier to G8.1F,  apply Shader Presets to G8.1F's Body and Legs surfaces separately.
    2) Add a dForce Modifier Weight Node to G8.1F. Copy the weight from G8F's dForce Modifer Weight Node to G8.1F's. Save a Character Preset.
    Then load the Simulation Settings Preset from the product, set up your scene and Simulate ~~
    The vendor should've given more Presets for G8.xF/M and G9 ~~
    2560 x 1392 - 462K
    Post edited by crosswind on
  • AsuCafeAsuCafe Posts: 557
    does it good working?
    So far so good ~ It works as expected, if you just need physics effect on breasts and glutes.
    You also can add some weight to other body parts, e.g. arms and calves ~~
