DazRodent Fur Not Following Custom Morphs
vuarsenal90vuarsenal90 Posts: 13
edited September 2025 in Daz Studio Discussion
Hi everyone,
I've created a custom morph to make my hamster look fatter, but the fur doesn't follow the morph, it just stays the same instead of inflating with the body.
Is there a way to fix this? Or is it simply not possible?
I noticed that even the built-in morph that makes the hamster's cheeks puff up when eating doesn't seem to affect the fur either, so maybe this is a limitation.
Has anyone dealt with this before or found a workaround?
Thanks in advance!
1920 x 1080 - 2M
1920 x 1080 - 1M
1920 x 1080 - 2M
Post edited by vuarsenal90 on
  • crosswindcrosswind Posts: 10,351
    The issue comes from a wrong setting on its SBH Fur.
    Select RodentFur node, in Parameters pane, turn on Show Hidden Properties.... Go to Path: General>Simulation>Hair>Follow, turn off Disable Target Surface Transforms (ss1)
    The Fur will follow the morph change ~~
    Edit: If you want to fix it once and for all, go to : your Daz Library\data\Sixus1\Daz Rodent 1.1\RodentFur\, open RodentFur.dsf with Notepad++, go to line 595635, change true to false. Save the file. Reload the fur. (ss2)
    2019 x 1293 - 543K
    1265 x 941 - 108K
    Post edited by crosswind on
    Thanks for the tip. I tried your method, but the fur just exploded when I turned off that setting.
    I also edited the source file as suggested, but when I reload the fur it still comes in with the value set to "on."
    1920 x 1080 - 832K
    1920 x 1080 - 2M
    I fixed the issue with Rodent base breed as an example... but you're using Guinea Pig.  I double-checked it and found Guinea's morph is problematic as well ( most likely a wrong ERC Freeze ...)  I remade the Guinea Pig's morph and it works as intended. (ss1~2)
    As for modifying DSF files of the Fur, they have separate DSF files in different folders:
    - guinea pig :   data\Sixus1\Guinea Pig\Guinea Pig Fur\Fur_Curves_437556.dsf
    - hamster:   data\Sixus1\Hamster\Hamster Fur\HamsterFur.dsf
    I have to say this product is really problematic...suggest you fill a support ticket ~~
    Edit: Hamster's morph is okay, the way of fixing works for it.
    2560 x 1392 - 2M
    2560 x 1392 - 2M
  • I got it working!
    You were right, turning off Disable Target Surface Transforms does the trick, but I also had to take one extra step: dial the Hamster Fur morph on the fur back to zero. That seems to make the fur follow the body correctly.
    Now my hamster is gloriously superfat. Thanks! :D
  • Never mind, once I posed the hamster, it exploded again.
    edited October 2025
    I'm sorry thatI don't know why then. I check the fur on other animals made by other vendors... with the same settings, they work well.
    Not sure if it's a rigging issue or the mode of SBH generation brings all these issues. Pls send a ticket.
