Import Camera from other DCCs
Is there any way to import a camera, even just position data, from either a static or animated camera from another DCC?
  • In what format(s)? At least you should be able to create a null or simple mesh that follows the camera position and rotation, then parent a DS camera to the imported null - a script in DS could probably read off other proeprties sfrom a suitable formatted label or data attached to the node if the transfer format supported that.
