Question on Sprite products (how to handle only one object)
Might be a silly question but anyhow:
I own quite some of Sprite's products but hesitate to buy more. Reason is that he/she tends to provide only one piece of wardrobe although let's say a bikini should be usually provided as a single top and buttom piece. Take the new https://www.daz3d.com/dforce-spr-moonlight-coast-bikini-for-genesis-9. From the description and readme I get that is again just one piece. So how to deal with it best once I want to kitbash and only use the top or bottom piece. Just make the other part transparent. Don't get it.
  • From the file list (http://docs.daz3d.com/doku.php/public/read_me/index/111803/file_list) it is an all or nothing load. There are no separate files for top & bottom.
    Regards,
    Richard
  • ElorElor Posts: 4,264
    edited September 2025
    A possible solution would be to create a conditionnal graft, this way you could easily hide the part you don't want. A vidéo by @Mada explaining how to do it:
    If you prefer, @Utiltarian has a product to make, among other things, easier to create conditional graft:
    https://www.daz3d.com/easy-geometry-hider
    Post edited by Elor on
  • These wouldn't be especially hard for an end user to split apart (use the geometry editor to delete the other half, then save the piece out - or, as a more advanced option, create conditional grafts to hide each piece) but it is disappointing when it's not done by default.
  • TaozTaoz Posts: 10,381
    So what does this mean?
    You can find new icons for this product in the following DAZ Studio Categories:
    • “Materials:Iray:Wardrobe”
    • “Wardrobe:Swimwear:Bottoms”
    • “Wardrobe:Swimwear:Tops”
    I mean, there seem to be separate tops and bottoms here, or what (not really into Smart Content categorization)?
    Post edited by Taoz on
  • felisfelis Posts: 6,648
    There is only one data file, so it must just be be the full outfit in two places.
  • crosswindcrosswind Posts: 10,358
    That was just generated from the product's metadata, i.e. both Bottoms and Tops are checked under Wardrobe > Swimwear.
    Even the Product Details were generated by AI... IMO, which makes less sense to me on such a simple "one-piece" that could've been splitted into two pieces for easier use.
    OK.  I've also come across a few characters with only full preset (no separate head/body presets) recently, which is annoying.  The more options, the better, and more products sold.
